My stupid question of the minute
RE: My stupid question of the minute
ORIGINAL: longlive289s
ya the trick shift stuff is really nice however it sucks when u still have a stock c4 which requires 8 quarts (i think just off the top of my head) and at about $4 a quart it gets a bit pricy
ORIGINAL: grruminator78
how do I drain the oil in the converter?
I have read in the past where guys have drilled a hole in the bottom of the converter, and tapped in a threaded bolt where they could drain the converter without this procedure, but the converter takes 5 quarts to fill it, so that is not saving you more than a quart or two of fluid.
Some converters have a drain from the factory. Remove the inspection plate and rotate the engine to see if you have a plug.
Soaring's method works very well for routine changes. If the fluid hasn't been changed in a while, consider looking for that drain plug in the converter.
If you go to almost any transmission or repair shop they can flush your trans for any where to $90-$150 dollars and you dont have to worry about screwing up your trans lines or transmission. And the flush machines they use now work better and clean the junk out of the trans better than doing it the way some people would do it.
hmmmm I am a lazy son of a gun..... pay someone else to do that or have an excuse to get out of the house for a while and down to the hobby shop... that's a hard one....
yourmom6990
09-14-2015 10:52 PM
