Disc Brake Help
Disc Brake Help
hey guys, i am looking at upgrading my rear drums to discs. i have decided to go with stainless steel brakes- force 10's. i know this is probably a stupid question but i need to decipher between a large bearing rear end, and a small bearing rear end.
RE: Disc Brake Help
69 is probably large bearing, assuming 9"...but I'll leave that to the experts to answer.
Before you go there, what's on the front? If the fronts are std, then you could be spending a lot more money than you need to.
also, check out the FAQ section. from memory there are a couple of articles about rear brake swaps
good luck and keep us informed ( i want to do mine too!)
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
