Follow up to oil pan removal....
RE: Follow up to oil pan removal....
Yep. You may as well replace it while the pan is off. That's what I did even though the old one still worked. I had no history record of how long the old one had been in there (probably from the factory) so I replaced it. They are relatively inexpensive, and the peace of mind is worth it.
Stock engine, get a stock pump (you probably already have it, but I'll vote anyway). You may wan to think about an aftermarket oil pump shaft as well. The stockers aren't as strong...I've twisted more than one.
ORIGINAL: sxs191
Thanks Soaring. I will do that. Should I get a high volume pump for a few dollars more or shouldn't it make a difference for cruising?
09-25-2015 06:30 PM
