MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   Classic Mustangs (Tech) (https://mustangforums.com/forum/classic-mustangs-tech-16/)
-   -   Engine won't run! (https://mustangforums.com/forum/classic-mustangs-tech/231900-engine-wont-run.html)
19JerseyStang64 Jan 16, 2007 12:59 AM
Engine won't run!
I finally got the new clutch, starter, and flywheel in my 67. I was never able to start it because of the shot flywheel and starter. When crank it, it only runs as log as the starter fluid burns and then shuts off. I thought there was no gas getting to the carb so i disconected the fuel line from the carb and try cranking it again. Plenty of gas came of the line so now im really confused. I also thought it could of been vacuum lines but they are all connected. Any advice would really help. Its a 351 by the way.
70coupe Jan 16, 2007 01:36 AM
RE: Engine won't run!
probbably the carb
mustanglover66 Jan 16, 2007 01:43 AM
+1 sounds like a carb problem ether pull it and rebuild it or put a new one in its place.
groho Jan 16, 2007 02:59 AM
needle and seat is probably stuck closed in the primary. You obviously proved it runs with the starter fluid.
Brandontyler65 Jan 16, 2007 03:07 AM
did you check for spark and what kinda carb do you have
FuzzyDiceRule Jan 16, 2007 03:23 AM
are the venturies clogged, or w/e happens?
Bulldog66 Jan 16, 2007 08:02 AM
Do you have access to a carb you're confident that works? Either way, replace or rebuild the carb.
ZZmustang Jan 16, 2007 09:08 AM
Yep
Carb
see if the excelerator pump is working. (look in the carb andmove the gas linkage)
ideal_mustangs Jan 16, 2007 10:48 AM
Like Groho said, its your needle valve stuck. If it runs when you pour gas in it and there is gas coming out of the fuel line, then obviously there is no gas in the carburator. The needle valve would cause that
19JerseyStang64 Jan 17, 2007 12:36 AM
Thanks for the replies. I'll take a look at the carb after school tomorrow and see what i can find. The carb is a Autolite 4100 (c5zf-L) and hopefully not a pain to rebuild.
© 2026 MH Sub I, LLC dba Internet Brands
