Whats the trick to removing the headlight switch, wiper switch, ignition switch, etc
Old 06-03-2007, 10:40 AM
66 Restomod
66 Restomod's Avatar
Default RE: Whats the trick to removing the headlight switch, wiper switch, ignition switch, etc
ORIGINAL: ponyx2
The paperclip in the hole only removes the lock cylinder, the switch itself is held on by the bezel, which unscrews.
65-66 bezels don't actually unscrew at least not in the traditional sense, maybe 67s are different. You only need a fraction of a turn to release the bezel from the switch, while you are collapsing the tension spring behind the dash to unload the resistance on the bezel where it's hooked to the switch.
66 Restomod is offline
Old 06-03-2007, 02:51 PM
65Raven65
65Raven65's Avatar
Thanks everybody, I got everything out. Finally!
[align=left] [/align]
65Raven65 is offline
Old 06-03-2007, 03:11 PM
66GTKFB
66GTKFB's Avatar
What did I do, leave out - 'jiggle'? The cylinder will not come out if you turn the key counter-clockwise (aka to da left), that's why it's called the accessory position. Now, in that accessory position, you use the paper clip technology and push in and go further left (aka counter-clockwise). Doing the 'push' and the 'twist' (was that a pair of Chubby Checker songs?) at the same time - works.
Jim
66GTKFB is offline
Old 06-03-2007, 04:43 PM
6marc5
6marc5's Avatar
I removed mine exactly how 66gtkfb said to do it and it came out easily.
6marc5 is offline
Old 06-03-2007, 05:15 PM
66GTKFB
66GTKFB's Avatar
Thank you.
Jim
66GTKFB is offline
Old 06-03-2007, 05:41 PM
ponyx2
ponyx2's Avatar
That's how to remove the lock cylinder. Jim has helped me on MANY items and I think we are talking of 2 different things. To take the actual switch out, the bezel has to be unscrewed, on a 67 for the switch part to be removed from the rear of the dash. It's all good, and glad you got it figured out. Flame suit on, just in case, LOL
ponyx2 is offline
Old 06-03-2007, 05:58 PM
66GTKFB
66GTKFB's Avatar
There's a special tool for 67 and 68 ignition switches, not required on 64 thru 66.
Jim
66GTKFB is offline
Old 06-03-2007, 07:54 PM
ponyx2
ponyx2's Avatar
I use a pair of needle nose pliers....am ducking again
ponyx2 is offline
Old 06-03-2007, 08:04 PM
66GTKFB
66GTKFB's Avatar
Congratulations - you saved youself $17.95 (plus tax and shipping). I've done the same as well.
Jim
66GTKFB is offline
Old 06-03-2007, 09:08 PM
ponyx2
ponyx2's Avatar
OK, truce
ponyx2 is offline
StalkerGT
11-28-2015 03:09 PM
Meystang
09-25-2015 04:05 PM
PNYXPRESS
09-14-2015 09:50 PM
TfcCDR
09-14-2015 12:08 PM
Wombatnation
09-13-2015 09:16 PM
Quick Reply: Whats the trick to removing the headlight switch, wiper switch, ignition switch, etc
