What's the cubic inches on a .030 over 289?
#31
RE: What the cubic inches on a .30 over 289?
ORIGINAL: Soaring
Thanks James.....that sounds about right. You'd be surprised at what some guys will do to their engines to gain 4.5 horsepower.
I have a 1970 396 (really a 402) in my garage, it still has a stock bore, It was not easy finding off the shelf standardpistons for an engine of this vintage, and limited production.
#32
I love these responses suggesting I should have known what the bore and stroke is on a 289, and that I should automatically know the formula to figure out displacement. If I knew, I wouldn't be asking. I thought this was a dicussion board, for questions and answers.
Thanks to those who gave a respectful answer. And no, I don't care about the added horsepower, I was just curious. I come from the Chevy school of rebuilding. (rebuilding a 350? Make it a 355 for the heck of it!)
[align=left] [/align]
#33
ORIGINAL: highhilleer
Well there's a couple of things going on here.
First, it doesn't matter what the displacement is if you bore the engine .3 over because youhave ruined the block!! Boring is done in hundredths of an inchso the question should be about boring 0.030". That extra zero between the decimal point and the 3 makes a big difference.
You knew what I meant
#34
ORIGINAL: 65Raven65
[align=left][/align]
#35
ORIGINAL: 65Raven65
I think I was more into showing of my computerdisplacement application than anything else, and then I just followed the conversation. I intended no disrespect whatsoever....
And,, BTW, the Ford stuff is new to me as well. (and yes, a .030 overbore is not an issue with most SBC)
James,
#36
65 Raven......we most likely have the most intelligent tech guys on here than any other classic Mustang site. My suggestion, and this is a suggestion that I give everybody, is that you do some research on your own by hitting google and going to the search feature on this forum before you ask aquestion on the forum so that you are well informed ahead of time about all the nomenclature of part names, etc. Once you get into the ballpark of what you are asking but stilll have to clean up a few things, then come on here and ask your question. Understand that this site is run by volunteers, and all the answers you are getting are volunteered answers.
#37
It'd be a little more power due to the increase in the compression ratio. For a 289 with 54cc heads and a .039" head gasket height, zero deck height, and zero piston dish, the compression ratio from boring the engine from 4.000" to 4.030" would go from 10.528 to 10.652. Also forgotten, the actual bore of the engine will not be 4.030 inches, but something a tad bit more to accomodate the pistons. My 302 is borded out to 4.033 inches.
#38
ORIGINAL: 65Raven65
*rolls eyes*
#39
ORIGINAL: 65Raven65
#40
Gosh, I'm sorry that I lack the clairvouyant ability to properly identify your automotive knowledge when you ask such a basic question. Your mistake is a common one and I thought it may be beneficial to clarify the point, if not for your benefit, then for the benefit of a real newbie who may be reading the thread. Other common mistakes are asking about a V6 and a "posi" rearend in a classic mustang.
ORIGINAL: 65Raven65
*rolls eyes*
