Here it is my Custom Linkage
Mach I Section Moderator
i picked all these parts up from lowes for about $13.00
http://i24.photobucket.com/albums/c2...carpics121.jpg
http://i24.photobucket.com/albums/c2...carpics120.jpg
http://i24.photobucket.com/albums/c2...carpics119.jpg
http://i24.photobucket.com/albums/c2...carpics118.jpg
http://i24.photobucket.com/albums/c2...carpics117.jpg
cuttin the 1/4" threaded steel rod (lowes)
http://i24.photobucket.com/albums/c2...carpics143.jpg
some final sizing
http://i24.photobucket.com/albums/c2...carpics145.jpg
the linkage all hooked up
http://i24.photobucket.com/albums/c2...carpics167.jpg
old carb
http://i24.photobucket.com/albums/c2...carpics139.jpg
well i got pissed cuz i couldnt figure it out, so thanks gothand.
i added text to the pics and stuff....this setup is cheap and wont break!
some final sizing
old carb
RE: Here it is my Custom Linkage
This board does not seem to like the capitalized IMG tags that Photobucket uses. I just changed your tags to lower case so we'll see if it works.
Jeff
Jeff
ORIGINAL: USMCrebel
ORIGINAL: gothand
Jeff
Jeff
ORIGINAL: USMCrebel
CUTTING THE STUFF
FINAL SIZING
ALMOST HOOKED UP
THIS IS A PIECE OF **** THAT WILL BE A BLOW THROUGH SETUP
CUTTING THE STUFF
FINAL SIZING
ALMOST HOOKED UP
just for a future tip, here's a trick i learned. If you have a bunch of pics with the IMG thing, just make the first one "image" rather than "IMG" then they all work for whatever reason.
the linkage looks good, nice work. nothin like cheap and functional!
Why not use some hemispherical rod end bearings instead of the eye bolts?
I think they would provide smoother operation.
http://www.grainger.com/Grainger/items/6G171
[IMG]http://images.grainger.com/images/products/6G170.JPG[/IMG]
Tim
Tim
ORIGINAL: Tims65
Tim
Tim
