ford 9 in.
Old 12-26-2007, 12:18 PM
racin66coupe
racin66coupe's Avatar
Default ford 9 in.
what cars came withthe ford 9in rearend that bolt up to a 66 stang? i heard a mid seventies versailles does but i am not sure
racin66coupe is offline
Old 12-26-2007, 12:44 PM
john721
john721's Avatar
Default RE: ford 9 in.
I sure hope so.... I have one I need to install! BUt to answer the question, yes, the Versailles rear does bolt in, with a few little mods from what I'm told, (leaf pad hole is different size)
john721 is offline
Old 12-26-2007, 01:20 PM
Daze
Daze's Avatar
there are several OEM housings used with the correct 52.25” wheel flange to wheel flange width. The first is an actual Mustang 9” housing. A few Mustangs actually came with the 9” housing but these units are nearly impossible to find and when you do find one they’re expensive. Other Ford options are the 1957-1959 full-sized Ford cars, the 1975-1980 Granada/Monarch and the 1977-1980 Lincoln Versailles. With these “other model” donor cars there is one immediate difference between them and an original 1964.5-1966 Mustang 9” housing and that is the Mustang housing has tapered tubing ends. A Non-tapered tubing unit can be used in a first generation Mustang but different u-bolts and mounting plates will be required. If you want to learn more about the Ford 9” in general one of the best sites on the Internet and the one where I got the information for possible correct length donor rear ends is www.ultrastang.com
Or you can do what I did and have a 9" and an 8" welded together
Daze is offline
Old 12-26-2007, 01:38 PM
racin66coupe
what would the advantage of getting a 9in and 8in welded together? also, what's would an estimated price be to get a 9in narrowed if it doesnt bolt in?
Old 12-26-2007, 02:09 PM
Daze
Daze's Avatar
I did mine my self but any competent machine shop could probably do it for around $200. Here are a couple of reason that I built this unit for a friend of mine.
1. Having the tapered axle tubing is period correct for a 65-66 Mustang even with a 9" rear end. Of course I only add that because it could be a valid reason, I personally couldn't care less about "period correct" I am putting a Jag IRS unit in my personal Mustang for heavens sake.
2. By using the "period correct" tubing existing u-bolts and mounts can be used so there is no need to source them.
3. Most mustangs came with 8” rear ends so donor housings and axles are easy to find and relatively inexpensive.
4. The 8” axles are 28 spline just like many of the 9” differentials and already the correct length.
5. All the other stock components such as brakes mount up with out having to modify anything
5. Most axle tubes from the donor 9" housing have different spring mount location or all kinds of extra mounts that would need to be cut of if you were only trying to modify the 9”
6. In many cases the O.D. of the 8" tubing is almost the same as the I.D. of the original 9" axle tubing. Making the mod simple.
7. My favorite reason because it is fun
Daze is offline
Old 12-26-2007, 04:06 PM
67 evil eleanor
67 evil eleanor's Avatar
Heres a link or two.
http://www.maliburacing.com/ford_9_i..._nine_inch.htm
http://www.kevinstang.com/Ninecase.htm
67 evil eleanor is offline
Old 12-26-2007, 05:59 PM
remicks
remicks's Avatar
Just curious, but why do you need a 9in? Are you doing something where your 8in wouldn't suffice? Or are you doing a 6 cyl conversion and just need a new rear end all together?
remicks is offline
Old 12-26-2007, 09:21 PM
racin66coupe
i am planning on putting 400-500 hp in it and heard it wouldnt take it. it is also a 6 cyl now so i need new axels and what not for a 5 lug conversion
Old 12-27-2007, 01:53 AM
andrewmp6
andrewmp6's Avatar
Cheapest place to buy a 8 inch or 9 inch housing is http://www.perogie.com/Rears.htm you can build up a 8 inch to handle that much power.
andrewmp6 is offline
Old 12-27-2007, 11:46 AM
racin66coupe
seriosly?
Quick Reply: ford 9 in.
