How To Set Ignition Timing?
Old 01-23-2008, 08:56 PM
SUPERSTEVE9219
SUPERSTEVE9219's Avatar
Default How To Set Ignition Timing?
Well recently I upgraded the carb on my 2v cleveland to a 670 street avenger and a performer intake and im having problems with the car backfiring through the exhaust and carb sometimes when its cold, I looked into the carbs manual and looked into the trouble shooting and they all said that a cause could be the ignition timing, I asked a few people and they all told me I need to change the timing to deal with the bigger carb.
Theres one problem though, I don't know how to [sm=smiley23.gif].
Could I do this myself? If not how much do they charge to tune the timing?
SUPERSTEVE9219 is offline
Old 01-23-2008, 09:57 PM
mustangmatt63
mustangmatt63's Avatar
Default RE: How To Set Ignition Timing?
If the timing needs reset and you do not have a timing light you can do it by loosening the Dizzy hold down bolt,start the motor and then turn the Dizzy a little bit at a time very slowly until it sounds real good go a little past that point until it starts to sound just a little rough and then turn it back until it sounds real good again and tighten it back down in that spot.That should get it pretty close!Hope this helps you and I hope I explained it right.Good luck!!PS Turn the dizzy holding the side of it not the wires!!
[IMG]local://upfiles/72436/375499E3F8484955878C0A445A4E2838.jpg[/IMG]
mustangmatt63 is offline
Old 01-23-2008, 10:03 PM
JMD
JMD's Avatar
I am too lazy to type it all out tonight,,,, so here is a link,,,
All you should need is a timing light and some chalk!
Don't let the long process intimidate you, it is really an easy process, and a process that is good to know when working with any car more than 10 or 15 years old.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
JMD is offline
Old 01-23-2008, 10:05 PM
djsprinklesnjo
djsprinklesnjo's Avatar
i asked this before, but your explanation seems easier. however what is a dizzy?
also if i did have a timeing light. then how do i do it?
djsprinklesnjo is offline
Old 01-23-2008, 10:20 PM
mustangmatt63
The Distributor!
Old 01-23-2008, 11:01 PM
Fordication
Fordication's Avatar
Time to take it to firestone and let them do it.
Fordication is offline
Old 01-23-2008, 11:03 PM
Fordication
DJ, where do you live. One of us may be able to help you out too
Old 01-23-2008, 11:09 PM
flyingfool
flyingfool's Avatar
aw, hes gotta learn SOMTIME!...
flyingfool is offline
Old 01-24-2008, 04:05 PM
SUPERSTEVE9219
You guys are awesome, thanks alot!
Old 01-24-2008, 07:40 PM
djsprinklesnjo
there is alot of things i know how to do, and some i dont know. but im a fast learner and want to do everything on this car myself. or with the help of a friend. i hate taking the car to a repair shop. the only thing i did was take it to and transmission shop, bc i didnt want to mess with the tranny. and i want to kick myself for not trying it myself.
if i can figure out electrical wiring and work on todays brand new cars, then i should be able to pick this classic car up easily.
anyway i would love any help or advise. im in staten island.
also i believe you should learn, read and ask as many questions before you try something new. knowledge is power. it cant hurt
Quick Reply: How To Set Ignition Timing?
