AJE racing front suspension install on a 67 mustang
RE: AJE racing front suspension install on a 67 mustang
one last look before I start cutting it up
I ended up using a sawz-all and plasma cutter to get most of it out, I still need to fine trim up everything use the spot weld remover and the air hammer.
went ahead and made a template out of cardboard and used a paint pen to mark the towers
ORIGINAL: andrewmp6
Not bad wonder how it handles since its more a drag racing set up.
hhhhmmmm nice turbo hehehe is it intercooled, i know this is about suspensions not turbos, but the reason i ask is because i'v got an adjustable wastegate turbo that is just aching to be put on a 460 with 126 gas and 40 lbs of boost, anyways daydreaming again
No, its not intercooled. Suck it up and do it!
here are some more pics
the stock upper spring plate holder needs to be removed for the new caster camber plates to able to be installed
using 14 g. sheet of material, made a template and cut out part of the plate using a plasma torch to overlay the tower.
welded the plate from the inside the tower under the fender
picture of the plates welded on
here is what the finished product will look like and the tower smoothed! :banana:
next step is steering...
our 67 has a 1 piece steering shaft and box so we had to cut it.
I am sorry to ask this....
But...I am a poor man....
What are you doing with the parts your pulling off?
I know there probably already in the dumpster...but it was worth a ask.
I could pay shipping.....lol
That kit looks great!
I have looked around your website many times and I just wanted to tell you that you are doing great things and please please keep it up!
Plus with this kit,you nowhave room for power steering!
