with 289 heads and block with comp cams magnum roller tip rockers
can I expect my push rods to be stock / longer / shorter? Or should I really purchase a tool to measure?
I do notice that the lifters are taller with the comp cam than the stock ones were.
RE: with 289 heads and block with comp cams magnum roller tip rockers
I would expect the stock length to be close.
Run the engine a while and then remove a rocker. Look for the wear mark on the valve tip. It should be centered and about .080" wide. If it's off center the length is wrong.
You may have to apply sharpi marker to the tip then install the rocker and crank the engine to get a good visible mark.
Don't waste your money on a check tool.
ORIGINAL: deadcarnahans
Check link for proper measuring:
http://www.compcams.com/Technical/FA...inGeometry.asp
And no, you don't have to buy an adjustable pushrod to do the measuring, you can make one out of an old pushrod cut in half and some 1/4"x20 threaded rod.
Thanks for the link. Useful stuff.
Question: Do the roller tip rockers have a true pivot point, as do the true rollers, or do they slide a little when they pivot?
Do I make same assumptions, based on rub mark, if I have rockers with roller tips verses a true roller rocker?
