289 to 302 H.O. yes? no?
#22
RE: 289 to 302 H.O. yes? no?
ORIGINAL: Scott H.
Take a 289 to 347, and you've got no more room to work with. and the pistons rock at the bottom of the bore. For a race only engine...OK, but for a street strip situation, not ideal.
On the 302, it's a similar deal, except less piston rock, and a bit more growth is possible.
Quite frankly, 347 sounds great for bench racing, but you can reach your goals with much less, and have room to grow down the road.
I'll bet PJC's 306 knocks down 350HP with ease.
Back to topic, piston rock is very minimal if the block is machined correctly to the correct tolerances.Even the new BOSS 302 block has shorter walls than the 302 (about the same as the 289)and the5.4" strokehas zero issues in that block. Don't get me wrong I amnot saying the piston skirts don't clear the cylinder wall(they do), but with proper machining and assembly this is not an issue evenin street cars.And this still does not change the fact that a 289 block is stronger than a 302 H.O. block. And yes IN STOCK FORM the 302 makes more power, but put the same parts in each block and they will make the same power, but the 289 will be able to withstand more rpm.
#23
An 87-91 would be your best bet I believe. They had forged pistons, forged rods, but a cast crank. I wouldn't put too much faith into this stronger block/block splitting, you won't be making that much power anyways, so imo, it would be better to get the 5.0, with it's roller cam, and forged internals.
Also remember when someone tells you the 196x 289 put out so much power, that is NOT net horsepower like it's rated today. It would have far less horsepower when dynoed against an engine today. Now of course if you want to strip it down and rebuild it with todays parts, ok, but thats a whole other story.
#27
ORIGINAL: Aussie66Fastback
hey PJC, i thought the reason the 289 was able to withstand more revs than a 302 was an issue with rod length on the 302s...rod length to somethingorother ratio????
Again, a 289 blockIS stronger than a post 1974 302 block. Please take both blocks apart andmake note of the difference inmain web material.
bradleyb
11-27-2015 07:50 PM
jaiidutch
09-14-2015 10:29 AM
