one piece oil gasket
Old 04-15-2008, 08:52 PM
  #21
baxsom
baxsom's Avatar
Default RE: one piece oil gasket
ok so i am hearing to use the liquid sealant on the one piece gasket or it will leak
and i am also being told to not use the liquid sealant or it will leak.
two completly different and oppostite answers
come on help me out here
baxsom is offline
Old 04-15-2008, 09:07 PM
  #22
JMD
JMD's Avatar
ORIGINAL: baxsom
Well there are plenty of opinions, I think that there may be a little confusion regarding what type of gasket we are talking about here..... As far as the one piece oil pan seals go,
IMO sealer should be used on the ends of the pan at least.....
As stated in my first reply, my son used one of these on his Chevy 350, first time up no sealer, leaked real bad, 2nd time up with a thin film of sealer 360 degrees, both sides of the gasket, no leak at all, anywhere...
Take it for what it is worth!
JMD is offline
Old 04-15-2008, 09:36 PM
  #23
cprstreetmachines
cprstreetmachines's Avatar
Alot depends on the fit of the pan also. Sealer or no, Canton sucks. The lip is in the wrong spot, and pushes out the seal alot of the times. So RTV or no, that thing is gonna leak. FWIW, I do do it for a living, and have never seen sealant cause a leak. I just try not to use in on the one peice because when/if the pan comes off, I don't want it to tear. they are kinda pricey compared to cork. The only place I use it is at the corner where it's round, wher the timing chain cover meets the block, and the round lips front and rear(on all of them now.)
cprstreetmachines is offline
Old 04-15-2008, 10:45 PM
  #24
Gingercar
Gingercar's Avatar
It's interesting reading these posts. I used the same (I believe) one piece gasket and used no sealer and it is leak free. However, I spent aLOT of time cleaning the block and the oil pan to make sure the surfaces were clean, and my oil pan was also straight. I believe that helped a ton.
Now if I could just get my C4 to stop leaking...
Gingercar is offline
Old 04-16-2008, 07:54 AM
  #25
baxsom
baxsom's Avatar
ORIGINAL: Gingercar
thats the next big project.
mine leaks right where the shift linkage goes in and i desperatly dont want to have to drop the tranny out
baxsom is offline
Old 04-16-2008, 11:18 AM
  #26
cprstreetmachines
ORIGINAL: baxsom
ORIGINAL: Gingercar
Don't have to drop the tranny. It just and o-ring on the oiutside of the tranny behind the kickdown lever.
Dathan
10-05-2015 05:52 AM
UrS4
10-03-2015 06:23 AM
jrrhd73must
10-02-2015 09:17 PM
ChampInSD
10-02-2015 04:55 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: one piece oil gasket
