Manual to P/S Conversion
RE: Manual to P/S Conversion
I know of no ready made kit for this swap, but the pieces are easy enough to assemble.
You'll need....
PS idler arm
PS pitman arm
PS centerlink
PS control valve
PS ram cylinder
PS frame mounted bracket for locating the end of the ram cylinder
PS hoses (4 total... 2 for the cylinder, one for pump pressure and one for pump return.)
PS pump w/pulley
PS pump mounting bracket
There will be some small parts also required... a new PS belt, some PS fluid, etc.
When all of this is priced out, unless you source the items used from a donor car, you're going to have close to $1k in parts. $1k for a PS system designed in the late 1950's that's barely adequate and prone to leaks? You may want to consider switching to a modern R&P unit. It'll set you back a few more $$'s, but you won't regret it.... the car will steer like an '09 Honda.
Dave
You'll need....
PS idler arm
PS pitman arm
PS centerlink
PS control valve
PS ram cylinder
PS pump w/pulley
Dave
Yes, there are kits. Here is one:http://www.parts123.com/parts123/yb.dll?parta~partsort
1400 for the old style and 1900 for the rack and pinion.
If you're looking for original equipment, Chockostang is your guy. He no longer has a web site, but sells his stuff on ebay. I bought a kit to upgrade my '67 coupe from manual to power steering a year ago. I paid somewhere around $800 for everything, including idler arm, power ram, pump, brackets, hoses, quicker-ratio steering box and pitman arm (everything dave mentioned above was in my kit). The only things I had to buy were a belt, fluid, and a rubber piece that clamps the hoses in place.
Something elseyou'll likely need is water pump and balancer pulleys (they'll need an extra groove for the new belt).Mr Chockley can sell you those also.
I'm sure he'll have stuff for a 6-cylinder Mustang also.
Mr Chockley specializes in original equipment steering and brakes.
His number is 217-882-2083
If you're looking for a rack-and-pinion upgrade, try
Total Control products at
http://www.totalcontrolproducts.com/rack.html
or
Steeroids at
http://www.automotivesteroids.com/Mu...Steeroids.html
or
Steeroids at
HRnB
GT350 S550 Tech
12-18-2015 09:35 AM
BeatnikFink
10-01-2015 08:00 PM
