MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   Classic Mustangs (Tech) (https://mustangforums.com/forum/classic-mustangs-tech-16/)
-   -   Won't start - any ideas? (https://mustangforums.com/forum/classic-mustangs-tech/473132-wont-start-any-ideas.html)
matt66gt Aug 11, 2008 11:55 AM
66GT - 289 A code - 4 spd Took the distributor out and dropped it back in - now it won't start.Turns over but won't catch. Electrical all looks good, I think I screwed up my timing. Either way,I don't knowhow to fix it- any body have any ideas? I'm pretty sure I was lined right when I put it back in but I dont know how to readjust the timing....
TripleHmotosports Aug 11, 2008 12:04 PM
RE: Won't start - any ideas?
Do you have Spark? Is the Rotor button turning? If so follow the steps below to reset timing.
Pull the #1 spark plug and put your finger over the spark plug hole and bump the engine over using the soleniod when pressure pushes your finger away you will be on TDC. Now check to see where the rotor button is pointing. Should be facing #1 spark plug wire. Make sure your harmonic balancer is set to zero. If not lined up pull distributor up enough to rotate to #1.
MAKE SURE THE IGNITION IS OFF AND REMOVE THE COIL WIRE TO BE SAFE..........
matt66gt Aug 11, 2008 01:05 PM
So I followed your advice and got er going. It hesitates for an extra second before it catches and runs a little lumpy....am I off just a little bit on something?
Either way many thanks for the tip...
Gun Jam Aug 12, 2008 03:20 PM
now you need a timing light to get it perfect. You want about 10 degrees of advance at idle
-Gun
© 2026 MH Sub I, LLC dba Internet Brands
