MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   Classic Mustangs (Tech) (https://mustangforums.com/forum/classic-mustangs-tech-16/)
-   -   I'm leaking (intake manifold?) (https://mustangforums.com/forum/classic-mustangs-tech/528646-im-leaking-intake-manifold.html)
Toddman0025 Apr 2, 2009 06:18 PM
I've got leak behind the distributor originating from the center of the intake manifold(?), is this just a matter of junk gasket or something more serious?
Here's some photos:
http://i224.photobucket.com/albums/d...Todd/leak1.jpg
http://i224.photobucket.com/albums/d...Todd/leak2.jpg
Toddman0025 Apr 2, 2009 07:18 PM
P.S. there's no fluid in the photos, but after about 5min of running there's a nice puddle around the distributor. It's definitely coolant. The arrows are where the coolant comes from.
JamesW Apr 2, 2009 07:21 PM
Sounds like you need to pull your intake and reseal it.
Toddman0025 Apr 2, 2009 07:51 PM
If this is what the gasket set looks like, what are those pieces at the front/back?
That's all that holds the fluid at bay?
http://shop.oreillyauto.com/product_...el/ms90116.jpg
JamesW Apr 2, 2009 08:18 PM
Do some reading back through posts. This was just described in wonderful detail in the last couple of days.
fakesnakes Apr 2, 2009 08:30 PM
Nobody uses the cork end seals, they are too hard to keep in place and get a good seal. Toss them and use a bead of automotive grade RTV.
Toddman0025 Apr 2, 2009 10:54 PM
How do you determine if you also need a new valley pan gasket?
Or are you supposed to replace everything at the same time?
http://www.ausfordparts.com/ebay/fel...el-ms96012.jpg
kalli Apr 3, 2009 04:15 AM
you say liquid which has me thinking water, but that seal is holding oil back.
So I guess it's oil you have there then.
jlg2002 Apr 3, 2009 02:53 PM
I'm with Kalli on this one, there's not supposed to be coolant there. If you see coolant, you have a leaking t-stat housing or hose. no need to pull the I'M.jlg
REAVER117 Apr 3, 2009 03:37 PM
I think you should be able to tell if you need to replace the valley pan gasket visually. I just cleaned mine and put it back on with some RVT. Make sure you get the correct gasket set for a 2 or 4 barrel Cleveland.
© 2026 MH Sub I, LLC dba Internet Brands
