5.0 Swap Radiator Hoses
I had good luck with these.
http://www.summitracing.com/parts/SUM-390124/
http://mustangefiswap.blogspot.com/
Scott,
I tried the hose for the big block 70 lower hose, the pump side was 1.5" but my pump ws 1.75" It had the correct bends though. I ended up using the Gates flex hose with the green stripe. The lower hose number was the same for all three V-8 motors that were avail that year. Bad part.... I cut the hose to length before checking the sizes so I had to eat the cost of the hose...
The 15" flex hose was perfect.
Scott,
That number didn't come up for the Mustang for any of the engines, all the engines for the 70 call for 20697 which has the two different sizes. The reason I didn't find the hose that you got was because it cross references to the 1970 fairlane, falcon, cyclone, montego, rancero and Torino all with any of the V8. I might just go check that hose out though.
Rod
Rod
