I see smoke.... um... Passenger side
It was a beautiful day here in indy today! 70 + Degrees. I thought Hey! I mize well start up the car. Well... As I went to crank the car from the ignition, I could see some light smoke from the passenger side. AS I did it a few more turns, I smelled something... Turns out the smoke was coming from the wire to the starter.
I could fell the battery positive cable to the solidoid and it was warm. So the wire from the other side of the solinoid was warm too...
What is going on? Did I not put the cable on the starter tight enough? Is the starter shot? AHHH..
Help would be great!
Thanks guys
Thanks guys
if the cable is ok, check as well if the positive cable on starter is not touching the starter housing itself slightly.
Happened to someone else on forums as well. he had it so bad that it wouldn't even start anymore
