going nuts. please help can't figur out motor mounts 85 stang with a 79 302
Old 05-20-2009, 05:10 PM
godrocksus1
godrocksus1's Avatar
Default going nuts. please help can't figur out motor mounts 85 stang with a 79 302
Im putting a 302 (block stamp 79) in a 65 coupe. AOD tranny. I bought the new cross member. I can't figure out which mount to use. Can someone please take a picture of theirs???
godrocksus1 is offline
Old 05-20-2009, 08:48 PM
Starfury
Starfury's Avatar
The block year doesn't matter as long as it's a 302. All you need are standard replacement V8 mounts for your car.
Starfury is offline
Old 05-24-2009, 11:04 AM
godrocksus1
Default help me before I beat the s&^% of of this car. 65 stang putting in a 79 302
I'm trying to put a 79 302 in a 65 mustang. I bought the $100 black brackets and I think I have the right mounts. It will have an AOD tranny. The motor mounts aren't lining up. I;m really close but the aftermarker chrome pan is hitting the centerlink. and the harmonic balencer is sitting on the sway bar.
Old 05-24-2009, 11:22 AM
guybored
guybored's Avatar
Was it a v8 before or was it a 6? You will need some frame brackets if it was a six then they actual motor mounts are use to attach the motor to the frame mounts. Are you sure it they are right and left on the right side?
guybored is offline
Old 05-24-2009, 01:02 PM
JMD
JMD's Avatar
I addressed my thoughts on the engine mounts on your other thread.
For the tranny mount on the 66, I bought stuff I thought (was supposed to) would work as a "bolt on", then cut it up, modified it and rewelded it when it became clear that "bolt on" wasen't in the cards...
There is a bolt in solution I am sure, but I didn't run across it. We should be putting the 302 in the Falcon next week, maybe I will make a "tech thread" out of it...
Not a Mustang, but close enough that EVERYTHING that matters will be the same...
JMD is offline
Old 05-24-2009, 08:30 PM
2+2GT
2+2GT's Avatar
2+2GT is offline
Old 05-25-2009, 03:02 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
Originally Posted by 2+2GT
that is a 66-70 setup 65 has mounts with a metal L bracket inbetween the shock tower mounts and the engine side mount. the photo use posted is an "ear type mount" as they are called
rmodel65 is offline
Old 05-25-2009, 09:25 PM
godrocksus1
So... I have entirely the wrong thing? I need the ones with the studs? I have the original brackets but I'm missing one of the "L" brackets. Anyone know where I can get an "L" bracket?
Old 05-25-2009, 10:45 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
ENGINE MOUNTING BRACKETS PAIR 65 MUSTANG 260/289
rmodel65 is offline
Granatelli Sales
01-20-2020 12:34 AM
Granatelli Sales
12-27-2015 06:28 PM
musnicki
09-23-2015 07:11 AM
Luke9222
09-04-2015 06:46 AM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: going nuts. please help can't figur out motor mounts 85 stang with a 79 302
