Best way to seal up the rear window..
Ive got some water getting through my window seal. What have you guys used to keep out the water? I was thinking about using window weld, but Im afraid that might be over kill for the rear. Please let me know what you think..
I used 3M Bedding and galzing compound. See the link below. It is specifically designed for sealing between the gasket and body. It stays very pliable. I used it after the window was in between the gasket and body then ran some in the channel where the window rests. Seemed to work well.
http://www.repaintsupply.com/pd_auto.cfm
yes and its non hardening.
I might go so far as to say you should redo the window seal because when you pull it out you will find a rust hole or 2 through the window channel. They should be patched and the channel coated with por 15.
-Gun
-Gun
KingRando
10-01-2015 11:16 AM
ccdguy
09-19-2015 05:20 PM
09-16-2015 07:53 PM
