Slop at top of Steering Shaft - Do I Need Sleeve? (Manual Steering)
I had some slop in my steering wheel (manual) so I removed my steering wheel. Shaft seems to be easily moving around at top where there are splines. Went to falconparts.com (full disclosure - it's a Falcon) and they carry a white nylon sleeve that goes at the top of the shaft to deal with this.
Two questions:
Have others this problem solved by using the sleeve?
Is it safe to drive until I get the sleeve?
Here is the part:
1960-1965 STEERING COLUMN BEARING SLEEVE Category: STEERING PARTS
Product ID: B1AZ-3518-A
Description: This is the sleeve that goes between the steering shaft and the upper bearing located in the turn signal flange. This part will keep the steering shaft centered and eliminate slop at the top of the steering column.
Price: $8.49
Two questions:
Here is the part:
Price: $8.49
I have the same problem. A new sleeve did not fix mine. On mine the sleeve does not seat itself far enough down the shaft to fix the sloppyness. Bad explanation but I'm not sure how else to describe it.
>>>>>"Description: This is the sleeve that goes between the steering shaft and the upper bearing located in the turn signal flange."
Ordered the part and won't drive the car (for probably a week waiting for the part!).
Question: Do I have to remove any part of the turn signal flange described above? Or can I just remove the wheel and put it into the space around the shaft?
Thanks
BB
Thanks
BB
