manually downshifting the FMX for passing???
I read that the C4 without a kick down cable installed can just be shifted down to second for passing or hard accelorations to keep the tranny good.
Can this be done as well with the FMX?
I'm curious because I don't want to have to spend 70 some bucks if i don't have to. Im just trying to get my car drivable. and I do plan to swap trannys later to a standard and I don't want to spend the money on it if I don't have to.
Though I suppose if it does NEED one, I can fabricate a rope kick down *And yes, there will be pics.... please don't say yes It needs one just so you can see my redneck idea actually done lol!*
I read that the C4 without a kick down cable installed can just be shifted down to second for passing or hard accelerations to keep the tranny good.
This is a normal operation of the trans. Doesn't do it any "good", it's just normal.
Of course. The 69-70 mach1 with 351 had the FMX, as did almost all 71-73 351 2V. You don't think performance was permitted? Of course, downshifting is normal.
I'm curious because I don't want to have to spend 70 some bucks if i don't have to. I'm just trying to get my car drivable. and I do plan to swap trannys later to a standard and I don't want to spend the money on it if I don't have to.
What is the $70 for? the 64-68 kickdown cable is $17.
the Lokar kickdown cable is like 75 dollars, and the other cables I've looked at are for C4s and look to short to work with the FMX being the FMX kick pulls down *I'd assume the C4 pulls up, not sure though*
BUT... I figured I could also rig something up, but I'll just down shift to second. It will make me feel like I have a Standard.... somewhat...
Thanks!
Thanks!
Thanks!
Thanks!
BeatnikFink
10-01-2015 08:00 PM
