Need opinions and help with seats
My 66 coupe standard seats are bad. They need new frames, foam and covers....almost everything. The seat tracks are ok.
I found 2 sets of seats. One set is out of a 98 Mustang, leather, but they have no seat tracks. 100 for the pair
The other set of seats is a set of headrested buckets out of a 69 Mustang. They have already been recovered and are complete and in great shape. 150 for the pair.
My questions are:
Will the 69 seats bolt right into my 66?
Can I use my seat tracks for the 98 pair?
Which ones would look better? I know it comes down to what I like in the end.
My car is more of a restomod.
Thanks as always.
Jeff
My questions are:
Thanks as always.
Jeff
I went the same way as you.....My 68 is a restamod as well, i put custom buckets in there, what i can tell you is that you are going to have a PITA of a time trying to use other brackets...put your stock brackets on the new seats, go with the 98 Seats. If your car is restamod, you will be much happier in the end.
I have repaired a lot of these. Not a big deal if you can weld. Rarely, as in the case of a convertible that sat with no top, corrosion does take them beyond repair.
Seat frames, wire sets, foam and upholstery are available new.
Good price, but a lot of modification to install.
These will attach directly to your tracks, bolt right into the car.
GT350 S550 Tech
09-29-2015 03:29 PM
