Hesitation and backfire all of a sudden
Backfiring through the carb 99% of the time is too lean of an accelerator pump shot on the carb. If the jetting is lean(explains pinging under load with minimal timing) then the carb will need a bigger pump shot to cover the transient lean since the mains take longer to pull fuel through a smaller jet when it first generates signal.
Set base timing at 8-10 and total timing at no more than 28-30 and then go drive it, if it pings then it's probably too lean.
What do the plugs look like?
I just replaced the plugs, the old ones didn't look fouled though. I dialed the timing back to 8* and it is running perfect, no backfiring or pinging anymore. It was backfiring through the carb when the timing was set at tdc. Don't know if this still means it is running lean or the coil is bad.
Well it started pinging again. I was in 2nd gear and accelerating when it happened. I'll check the timing tonight to see if it has changed. I've never messed with the air/fuel mixture on the carb before, a little afraid of screwing it up.
Omgitsa88Stang
10-05-2015 07:33 AM
zanemoseley
09-06-2015 12:58 PM
