What would cause cassette player to buzz?
I'm not really a wiring nor sound expert, but I'm curious why my cassette player buzzes really loudly while its on. The buzz seems to change with engine RPM. It used to not be so bad, but it has gotten worse. (though I have just replaced the majority of the ignition system and have not tested it since.
What could I look for to diagnose the problem? Where could I start?
It most likely is alternator whine and being that it's fine while the car is off confirms that. You should double check your ground to the radio and amps if you have any. Also check cabling to amps (if applicable) to make sure no line input cables are near power cables. That's a a start.
You may also replace the RFI solenoid mounted to the voltage regulator, if it's still there. The whole point of it is to help remove RFI from the voltage switching in the regulator.
Also, what wires are you using? Aftermarket "performance" wires tend to have poor RFI shielding.
Some new BWD wires which I have not tested yet along with the rest of my ignition stuff such as the spark plugs.
Is there some other name for the RFI solenoid? Having a hard time looking that up
It's a little metal cylinder wired up to the voltage regulator.
