Anyone have improved upper arm shaft pics?
Does anyone have decent pictures of the improved style upper arm shaft? It looks like they've turned down the shank of the shaft to accept an O-ring. I can't tell from the pictures I can find what else they modified.
My shafts are in decent shape but the boots are shot. I'm trying to put my lathe to use and save $150.
$150? $50 should get you a new pair of shafts, with caps and seals.
using a rounded tip will eliminate any problems with stress risers. the weakest point is the troughs of the threads (minor diameter) and I won't be going anywhere near that small. it'll only be even with the thread major diameter. we're talking about removing like 0.040 here.
the improved style are about $75 each. yeah, you can get stock style for $50 each. it doesn't cost me anything to try. worst case is that i have to buy new shafts.
well the stock ones taper slightly from the thread to the bolt boss. that won't work for an o-ring; there just isn't enough space.
That's a pretty small o-ring, though the stock seal is more like a 3/16 thick o-ring.
There is a picture of it on NPD classic mustang catalog, page 73.
Basically there is a rubber seal that seals the shaft to the outside of the end cap. I can't see how those 2 extra seals justifies an extra $30.
also, where can I get a complete shaft for $25 each? they're $50+ everywhere I've looked.
my stock caps don't look anything like that. they have a large boot that goes on the outside of the cap and then steps down to the pivot. maybe they're not stock? i'm just trying to find a way to keep the grease in.
also, you guys know I have a '67 right? '66 are cheap, '67 are not.
