WHAT IS THIS??? Photos inside.
Well, I just got my first car back from my grandparents after many years of being away from it. They did a lot of work to it like paint, interior, etc.
One thing they didn't really focus on was the engine. Its a 200 I6, and it runs OK, especially for being a somewhat fresh rebuild. I will eventually be ditching this motor for a fuel injected 331, but that is another story.
Right now I just cruise in this car once or twice a week, maybe 15-20 miles. I however have been noticing some vapor coming from a port in the drivers side of the block just in front of the distributor. It is a wide open hole, and while the engine is at operating temp, a good amount of vapor comes pouring out. Im guessing that this was for the SMOG equipment that originally came on the car, but is now off, or some crude PCV setup.
I have seen cars with tubes coming out and down from this hole, and I have seen them with what looks like no plug, but I just cant tell. Please help me... What is this and should I plug it, run it or what? If I need to plug it, I can fab something up, but if there is a cheap, made for this plug out there, I could go for that too.
So, here are the photos.
And sorry for my newbness. I know my way around most V8's, and just about any late model, especially chevy's, but this just kinda has be baffled, and my google-fu is weak on this subject as well.
Thanks all!
Thanks all!
draft tube
I would like to find more about the " draft tube" I get how it worked, but I read that race cars don't use that or cvr but something called a venturi tube and scavenger , does the draft tube or cvr do something besides geting rid of crankcase vapor?
The angled tip, sticking out in to the air flowing under the car has a slight vacuum on the rearward-facing opening, and sucks the vapors of of the tube.
The PCV does the same thing, only better, by using manifold vacuum instead.
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
