Rear Axles - Befor and after
I realize these aren't the same axles, but both were pretty much in the same conditions before and after. A coarse wire brush did the job.
Should I be concerned about that edge?
You need to be sure that the drum (or rotor) is flush with/on the flange. Just put a straight edge on it to make sure it is flat. It doesn't look to be hit hard enough to bend the axle but you could check runout for a piece of mind.
buddy of mine has vibration at back wheels which are caused by that wheel attachment part being wobbly. His is bent (maybe the previous owner used slicks at some stage). so make sure to check on the above. although it doesn't seem to be mayor it might cause imbalance
musnicki
09-23-2015 07:11 AM
Daleford
08-10-2015 08:30 PM
