MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   Classic Mustangs (Tech) (https://mustangforums.com/forum/classic-mustangs-tech-16/)
-   -   67 I6 removal Q's (https://mustangforums.com/forum/classic-mustangs-tech/596133-67-i6-removal-qs.html)
67mustangreg Apr 12, 2010 08:30 PM
67 I6 removal Q's
Okay, what is the right way to unhook it all? I already took off the top hose from the black to rad and spilled coolant everywhere. caught the rest and will dispose of it properly.
what else? spark, gas and coolant. so radiator I think i can figureout...what about the gas lines? do I plug the end of it?
basicly, what are all the things I have to unhook and how. thanks for any advice!
67mustangreg Apr 12, 2010 08:32 PM
figured the part about the lower rad out.
67mustangreg Apr 12, 2010 10:30 PM
okay, now I need to know how to take off the trans cooler lines from the rad. if i just take them off, can i plug the holes and not have to drain the entire trans of fluid?
palerider Apr 13, 2010 06:40 AM
yes - just plug tubes you will be fine.
67mustangreg Apr 13, 2010 08:04 PM
while taking out the old motor I got as far as having only two bolts left and the throttle linkage. the rest of the bolts came out fairly easily but the two of them left are rounding off instead of loosening. i hit them with wd40 and still didnt budge. any ideas? I have a blow torch but that’s right next to the plugged gas line.
2+2GT Apr 13, 2010 08:24 PM
Um, what are these two bolts attaching?
67mustangreg Apr 13, 2010 08:32 PM
one of them is going from the back side of the bellhousing into the block and one is down below, going from the block side into the bellhousing. it's smaller then the 1/2(or is it 9/16ths?) inch one up top.
© 2026 MH Sub I, LLC dba Internet Brands
