Switching back to manual
Ok so my buddy got a 68 mustang and found out it was originally a manual (manual pedals still in the car and C4 doesn't have kickdown or neutral safety are some pointers). All decoding info is gone except the vin which can't help.
How can we be sure that it was a stick? does the floor look any different where the shifter goes?
Either way he wants it manual, so what would be more correct? a 3 speed or 4 speed in a 302 4V.
like i said the pedal assembly and rod that goes through the firewall are still in place. what all entails the swap back? of course the tranny, but what about crossmember, bellhousing (can the c4 bellhosing work?), driveshaft, etc. thanks.
The factory-punched hole for the upper clutch rod will be a dead giveaway.
Nope- Same hole.
If the car is a J code 4V, it was pretty likely to be a 4-speed. Get a Marti report and you'll know everything there is to know about the car.
Bellhousing, trans and shifter, reverse light switch w/starter bypass, speedo cable if it's a 4-speed, bellhousing, flywheel, clutch assembly with pilot and release bearing, release lever and boot, lower pushrod, pushrod spring, equalizer, equalizer engine and frame pivots with bushings and seals, upper spring, upper pushrod and seal.
C4 & smallblock 3-speed/4-speed used the same crossmember.
Not even close.
, driveshaft
Probably the one you have will be fine.
Nope- Same hole.
Not even close.
, driveshaft
http://www.cjponyparts.com/product.asp?pn=CK1
http://www.cjponyparts.com/product.asp?pn=CEBK4
http://www.cjponyparts.com/product.asp?pn=C7ZZ15520A
http://www.cjponyparts.com/product.asp?pn=SC6
i think this covers everything minus the trans and bellhousing and shifter. those we will have to hunt down. wished we started sooner seeing how we coulda got stuff from carlisle. thanks for the info.
p.s. further inspection showed a cut reverse light harness (definitely 4 speed) and original punched hole in the firewall. thanks. whether it was 3 or 4 speed we don't really care at this point. it will never have its original drivetrain so we will go 4 speed to keep the older feel if you know what i mean.
another interesting thing, did the manual mustangs have 9" rears? if not someone put one in.
ShaneB26154
35
03-04-2021 04:05 AM
bond007
08-26-2015 11:36 PM
HorsePower99
08-26-2015 11:29 PM
jpplaw
08-22-2015 09:29 PM
