1967 289 Low Idle
Guest
Posts: n/a
1967 289 Low Idle
hey guys tell me if you what you think i should bout this.
whenever i start the car if its not warmed up from before i have to give it a little gas either while turning the key or after i start i have to keep revving it up slightly to keep it on. Now i think its because of Low idle speed but im not sure.
Also im going to do a carburetor rebuild anyway so would that fix it?
If it idles fine when warm but not when cold then it is the fast idle cam adjustmest on the chocke side of the carb. Rebuilding the carb will not fix the problem unless you adjust the fast idle when you rebuild it. Also it may be that the choke is not working at all. Check that too.
Adjusting the fast idle screw takes less time than I spent writing this note.
if you can't find it at start, open the throttle plate while looking between main body and that black cylinder for choke. the screw that moves when you operate the thottle is the fast idle screw. and ya. post a picture of your carb. you never know the previous owner might have removed it or something stupid like that
Guest
Posts: n/a
http://i33.tinypic.com/ao6oi0.jpg
i found the screw tightened it a bit and the car starts like a charm everytime!
~thanks
*i put a pic of the carb it could be a double barrel but it looks like a single one to me.
~thanks
