mechanical solid roller cam in 69 block
Old 09-16-2010, 04:59 PM
GT350son
GT350son's Avatar
Yeah I'm gonna decide to go with a hydraulic cam. And if i'm guess right a 351w non roller block cam will fit in a 302?
GT350son is offline
Old 09-16-2010, 05:03 PM
GT350son
GT350son's Avatar
Originally Posted by Gary H
It would be cheaper to by a roller block :-)
Do alot of research, some use a smaller base circle cam. So you cant use just any roller cam out there. The crane kit uses a regular cam, but $450 a set lifters.
What are your goals?
Gonna make it my street/strip car but mostly strip. high 400 low 500 hp.
GT350son is offline
Old 09-16-2010, 05:56 PM
67mustang302
67mustang302's Avatar
What block is this? A 351 or 302 block?
67mustang302 is offline
Old 09-16-2010, 06:28 PM
GT350son
GT350son's Avatar
302 that i'm stroking to 347
GT350son is offline
Old 09-16-2010, 06:58 PM
Gary H
Gary H's Avatar
302 and 351w cams will interchange.
Good luck getting that much HP. Unless you boost or spray it, it's not that easy. What heads etc?
Gary H is offline
Old 09-16-2010, 07:15 PM
GT350son
GT350son's Avatar
dart 195 cc heads, scat 347 rotating assembly, edelbrock air-gap, holley 650dp, bbk equal length headers
GT350son is offline
Old 09-16-2010, 07:28 PM
Gary H
Gary H's Avatar
Decent combo, but it's not going to make the HP goals you want. I'd guess about 400 at the flywheel depending on cam and compression. Before you get a cam, talk to some of the cam companies and see what they recomend for what you have.
Gary H is offline
Old 09-16-2010, 07:37 PM
GT350son
GT350son's Avatar
What would you suggest for a low 500s hp 347 on pump gas?
GT350son is offline
Old 09-17-2010, 04:24 AM
67mustang302
Bitchen high dollar heads for starters. Like some TEA ported TFS TW heads, with a LIGHT rotating assembly. Custom cam, probably more like a Vic Jr intake, and at LEAST a 750cfm carb. And you'll prolly be turning 6,500rpm, maybe more.
Old 09-17-2010, 07:01 AM
Gary H
Gary H's Avatar
^ What he said. Other heads would be the AFR 205-225 and the edelbrock victor jr's. And then you're looking at the limits of the stock block.
What ET's do you want to run with the car?
some ideas
http://www.airflowresearch.com/ford_dyno.php
Gary H is offline
Quick Reply: mechanical solid roller cam in 69 block
