1967/1968 Convertible Glass Rear window?
Hello all. On our 1965 Mustang convertible, the previous owner had put a 1967/1968 optional glass window in when she had the top replaced (in 1978). Since then, the material in between the two pieces of glass has deteriorated, leaving a gap in between them. Does anyone know if that is avaliable to put back in there? Right now, we have been putting white tape across it to seal up the hole, in case of rain, but we would like a more permanent fix, without changing the top.
glass window repair for conv top
The connector between the two window halves is silicone. To repair this requires a little care and knowledge of caulking. You can use a SIKA brand silicone tape called "123-tape" on each side of the glass halves and the SIKA 190 silicone to glue the whole contraption together.
Apply silicone across the rear plate of the glass adjacent to the split while the glass is laid flat on a stable surface, apply by pressing, the 123 tape, clean mess. After this application dries, overnight, flip the two glass halves over very carefully and slightly overfill the seam between the glass halves. Press the 123 tape onto the seam being sure that no voids are present. Place some but not a lot of weight on the installed 123 tape during both applications to be sure you maintain a clean flat appearance.
I understand that to preserve the glass joint longer, some people unzip the glass before putting the tp down to reduce the stress on the joint.
