Power booster and hydraulic clutch master
I just purchased my 4 wheel disk brake kit from Vintage Venom. I would like to go power but don't necessarily have to. I currently have a hydraulic master cylinder for my clutch. Is there a late model power booster that is smaller and be able to clear my clutch master? Also, what is the most suitable prop valve I should use?
I have a kind of generic 8" double booster on my Lincoln, it does a real good job for a small unit. If you have a little better than 4.25" clearance from the center of your brake m/c it should fit, I have used a 7" unit that worked pretty good also.
http://cgi.ebay.com/ebaymotors/8-DUA...item5196248e13
This is the one I used.
Oh yea, I kind of like the SSBC prop valve.
http://cgi.ebay.com/ebaymotors/SSBC-...item4cf1f3a090
I just found a web site that shows a '94 and later Mustang master cylinder on a 1990 5.0 booster will work on a 68. I have to modify the pedal and drill new holes for the booster bolt pattern.
Thanks Jim, I'll check out that link.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
uberstang1
09-20-2015 06:42 PM
ccdguy
09-19-2015 05:20 PM
