T5 Backup sender and Nutral Safety switch
Now that I have the T5 in, the back up sender uses 4 wires, the original 3 speed only had wires 2. I am thinking just tieing the 2 hot and to grounds together and hooking up to my stock harness. will this work, if so which ones are hot and which are ground?
also the neutral safety switch, i have no intention on hooking it up, can i just pull the switch and plug the hole with out affection the trany?
Thanks
Thanks
Thanks I need to readdress this later.
NEW issue---------
Got the car off the stands for a test spin. as soon as i hit 3rd gear a TINGING noise started, ONLY when the clutch is out and accelerating over 15 - 20mph (speed O is not connected). the noise is constant and dose not increase in speed, dropping gears the noise stayed. I did not have the trany rebuilt or inspected, so the true condition is unknown. Is it the tranny or did i bend the tines on the pressure plate?
Trany came from a 87 5.0 and numbers match 86.5 - 89 WC-T5. I did not pull the clutch and pressure plate as i probably should have. I used the original 289 bell and kept the clutch in place.
Any advise?
NEW issue---------
Any advise?
The noise does not increase with trans speed? I can't explain that. even if the clutch or engine was falling apart, it should change with speed.
Thanks 2+2. I need to correct my self, my first test drive was vary short.
I went for a second test drive tonight. through in some speed outside a residential. what i truly found is when accelerating the noise sped up and faded (in loudness) and when I slow down the noise slows but gets more pronounced. sounds almost like a piece of sheet metal dragging on something. Its realy not a "Ting" its more of a slapping (or bouncing) dragging sound only when the clutch is not depressed. the noise is completely gone when at idol.
