how to seal intake manifold
Just did a set with Fel-pro gaskets and the instructions say to glue the cork gaskets to the block with high tack gasket sealer. Ensure they don't move on the block prior to installing the manifold. Worked fine for me. I have done it with RTV also, that worked fine as well.
there's only one way. ditch the cork there. it's no good. thick bead of RTV, make sure to overlap the gaskets a bit (so that the bead continues onto the head for about an inch getting thinner there. works every time for me. never seeped
i want to avoid wet to dry interfaces.
i will look for slow setting rtv?
maybe the only place for cork is ireland and wine
And very true on "Cork". good name for a town but no use for intake gasket :-)
Kalli
jwog666
12-27-2021 08:09 PM
