65 temp gauge not working
I replaced the sending unit and the gauge itself. the fuses look good. is it possible this doohicky could be the problem? it has a wire going from it to to the gauge. i tried the search function but it doesn't seem to be working.
ok so my temp gauge still isn't working but now when my lights are off the dash lights are on and when the lights are on my dash lights are off. i put 4 new bulbs in and need to get 4 more to replace the others, but they are all working at the moment. the dimmer works as far as dimming the dash lights but only when the switch is in the off position. everything worked fine last time i drove the car, except temp gauge, so i cant figure out what is going on. the only thing I've done is put in a new gauge and 4 new bulbs. right now the gauge cluster isnt installed. is it possible it needs to be installed all the way to properly ground it?
Yea its not grounded if its not mounted. I just went through the same thing, I made a temporary ground out of alligator clips and some 10ga wire, clip it to the cluster and then to a ground for testing.
You can test the gauge with a D cell battery, jump the + side to the that goes to the constant voltage unit and the - to the side going to the sender. It takes a minute but the gauge should slowly go up.
I bet if you have everything pulled out something is grounding causing the lights issue.
Ive heard this said before and had it happened to me also.new sending units are not all the same.Some people try a lot of different ones until they find one that works with their gauge.I never looked at more than one.replaced the whole thing with an aftermarket gauge.
So I put all new bulbs in and put it all together and now my fuel gauge isn't working either. It was working while I was replacing the temp gauge but I'm wondering if all the fiddling around in there finally did the IVR in completely. My oil and Alt light work just fine as do the instrument lights. I would prefer not to buy a IVR right now if I don't need to as money is kind of tight right now. If I have to I will though.
[QUOTE=Oafboy182;7535973]So I put all new bulbs in and put it all together and now my fuel gauge isn't working either. It was working while I was replacing the temp gauge but I'm wondering if all the fiddling around in there finally did the IVR in completely. My oil and Alt light work just fine as do the instrument lights. I would prefer not to buy a IVR right now if I don't need to as money is kind of tight right now. If I have to I will though.[/QUOT
