will this be the end of my vibrations?
#21
Kali, just a thought. Since you mentioned angles. I would try to get your shaft angles to 3 degrees or less. Also, make both ends the same, but opposite. I believe that you can also shim the axle to make this easier.
#22
well on club meeting everyone who had any kind of puller brought it and last night I changed the steering over. I had to take the driver side header off to get the puller on. what a nightmare. 1 hour job->3 hour job :-(
well anyway the steering is in, the old crap out.
I gained about half an inch clearance, so I guess when i drop engine by half inch I'm where I have been before ... ?! I was hoping for a bit more.
anyway ... the steering got a bit tighter with all new balljoints and at least I can now say that all 6cylinder remainders are gone from my car :-)
maybe next week I'll give it a lash. we have to get 2 cars on the road for a show on weekend, so I'll be a bit busy up until then
Stepman: ya, the gearbox is 6 down, the pinion 4 up. so it's inbetween the two, but the working angles at u-joints are too high (driveshaft to gearbox+driveshaft to pinion). it's almost 10 degrees added up. if i raise tailshaft a bit (with dropping engine) the whole thing will be straighter. further I hope with the adjustable mounts I can move theings sideways a bit to get a straighter line in the driveline
#23
I would try shimming the tailshaft 2 degrees and see what that does. It's easy to do at the tranny mount.
#24
I may not be understanding your statement, so bear with me. You want the imaginary center line of the gearbox and rear differential to be parallel. Ideally, they should stay parallel. This is regardless of angle as long as it is within the working range of the u joint. If they can't be set parallel, my local driveshaft guru told me to keep them within 2 degrees and they should be fine. It sound like you are right at the 2 degrees. I don't remember for sure but you should be close to ideal. I don't recall what allowances are made for torque rotating the diff on the springs. If you set them static parallel, they won't be when driving due to torque acting on the leaf springs.
I'd love shimming the transmount as you say it's very simple and straight forward. There's craplots of room between tailshaft and car floor. however there's only very little room just front of the mounting. There's a structure going across the tunnel which is very close to hit the T5. Any lifting will cause to hit it :-(
I even thought about cutting a piece out of there ... that's how I ended up with the idea of lowering the engine
#26
it will look like that \/\ instead of \-\ now. the working angles would be even worse
