68 over heating after upgrades
IMO, your TWO ROW copper radiator is your weak point.... (I think it is even marginal for a stock V-8)
I think a 3 row copper or a true (big tube) 2 row aluminum would help with your cooling capacity.
The fact that it worked ok with your cast iron heads does not mean that it is sufficient with your new heads. I BELIEVE that aluminum heads place a greater load on the cooling system than cast iron, plus the improved performance of your car will make more heat.
I had stated in the other thread that I don't worry much about temps as high as 220* or even 230* when not accompanied with boiling, but still your cooling system would benefit from a thicker radiator.
Any resolution on these issues? My 68 is having similar issues now that I added an A/C.
Got the car back today and here is the heating issue results:
steam holes were already there. installed new high flow t'stat not sure what temp will ask later.
From shop to home is about 20 miles. When i started it was at about 150 deg, had just been test driven, temp outside was 97, left a/c off. After 8 miles driving 55 stopped for light was at 195 deg. After 8 more miles at 62 mph got up to 209 still no a/c. Slowed for next 2 mi to 35 temp dropped to 200 still no a/c.
have not checked for air in system yet waiting for it to cool down a bit. i looked for radiator shops in my area and cannot find any. Was told plastic rads put them all out of business. If i can find one what do you think about cleaning and rodding and add 3rd core or should i just buy new aluminum rad?
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
