Autolite 1100 Carb Adjustment Question
Hi guys,
I have a question about adjusting the Automatic Choke Plate Clearance (Pull-down) and Fast Idle Cam Linkage on my carb.
The '66 workshop manual says to:
The automatic choke fast idle cam linkage must be properly adjusted before performing the choke plate clearance (pull-down) adjustment.
1. Insert a gauge pin or drill of the specified clearance (Part 10-8)
thickness between the throttle plate and the side of the throttle bore. Hold the throttle plate against the gauge pin or drill (Fig. 7). Close the choke plate and turn the fast idle screw inward until it just contacts the fast idle cam.
2. Place a drill or gauge of the same thickness as the specified clearance (Part 10-8) between the choke plate and the upper body wall (Fig. 8). Close the choke plate on the drill or gauge and hold it securely.
3. Close the throttle until the fast idle screw touches the fast idle cam. Adjust the plastic nut to just contact the swivel on the choke lever assembly.
At the top of the column on the carb specs page it mentions a 0.036" gauge. Down the column across from my carb it shows 0.130-0.150". I assume that a 0.036" gauge should be used first for the fast idle adjustment and then a gauge of 0.130-0.150" should be used to adjust the choke valve pull-down. Does anyone know if this is correct?
Thanks!
Paul
Thanks!
Paul
Hi guys,
Thanks!
Paul
Thanks!
Paul
Autolight 1100 Problems
I have a 1966 Mustang Sprint 200 6cyl auto with a Autolight 1100 carburetor.
I set the timing and it helped it start and run much better.
The car starts and runs good when it is cold and the choke is closed.
As the engine runs and the choke starts to open the engine dies before the choke is open all the way.
I adjusted the screw at the base of the carburetor; that didn't make any difference.
What now?
What now?
Daddys Girls GTs
09-14-2015 08:46 PM
jaiidutch
09-14-2015 10:29 AM
