66 mustang 4 row radiator
Hey guys
Need some help here...I bought a 4 row alluminum radiator on ebay with the electric fan and shroud. There is no way this will every fit. Any suggestions?
Thanks
Thanks
Its for a 66. The radiator fits but the electric fan they give you is too thick and the shroud adds 1/2in to the equation. The fan cant clear the water pump.
If you take the shroud off and mount the fan directly to the face of the rad would you have the room need? That is how i mounted my set up and i have about 1/2 in between the water pump and the ele fan made my own brackets, its very easy to do.
The fan I have is 3 3/4 inches thick. Thats about all the room I have from the radiator to the nose of the pump. I just bought a slim 2.6inch fan. Hopefully it sits in place. I will keep you guys posted. I dont think I can squeeze the shroud in there.
Without a shroud, the fan will be minimally effective. The point of the shroud is to allow the fan to suck the air it moves from the far side of the radiator, thus cooling the radiator which in turn, cools the coolant. Without the shroud, the fan draws air from the point of least resistance. In this case, it will be from the sides, top and bottom of the fan on the engine side of the radiator.
