Overheating & A/C Lessons Learned
90 degree weather and idling with the a/c blowing
here was the issues I was having a few days bacl
https://mustangforums.com/forum/clas...ng-w-pics.html
Final Fixes:
Spal fan
ditched aluminum shroud (blow back issues possible)
full pressurized chem flush
water wetter
oil change
and what finally did it (mainly)
Replaced and incorrect or faulty temp sensor. My mechanic was scratching their heads as well after to the a/c install since the new rad was pretty good in their opinion though they didn't love the fan. After taking it for a spin with the Spal (minus shroud) they actually check the engine temp and realized the engine was running around 188 but was reading close to H. With the new sender in they re verified everything once I came to pick it up. Reality is I probably wasted hours researching and stressing over heat issues when I should have verified that there actually was an issue.
On a side note the Old Air system works amazingly and blows very cold (one need the first fan level even in this heat wave). I took some new cleaned up photos of my engine bay. Hope this helps.
https://picasaweb.google.com/W.Casag...eat=directlink
Final Fixes:
Spal fan
water wetter
oil change
Ynasef - I would try without it first. The shroud I had wasnt the best and it covered the edge of the fan which may hav caused blow back. Also I could not mount my fan on the outside of the shroud due to space and that may have caused issue. Try it without with the a/c blowing and stuck idling to recreate a bad summer traffic jam and if you stay cool then why bother.
Norm
What did your mechanic do to verify the sender was bad? I'm having issues with mine trying to overheat (according to gauge), and I've run through the typical issues to check short of installing a new water pump or pulling the heads off to check that the gaskets were installed correctly.
He let the car idle and start moving past the middle and then checked the temp with an infrared laser gun. He shot the water pump/ thermastat housing and compared that to the needle in the dash. I was running 188 and it was reading H.
That should make you feel better and the AC should definitely make you feel better in the next couple of days. Tomorrow is supposed to be 101° down here in NJ.
I much rather have a faulty sending unit any day!
