Limitations of a T5
I have about $1300 into my T5 Conversion.
350 used T5
25 used bellhousing
100 flywheel
150 clutch
130 cross member
225 hydraulic clutch setup
300 aluminum driveshaft (not required)
30 ARP bolts
40 T5 bushing, seal and steel input retainer
Info on T5 and choosing the right one:
http://chris66dad.tripod.com/id38.html
T5 conversion info;
http://chris66dad.tripod.com/id33.html
Hydraulic clutch pictures and parts info:
http://chris66dad.tripod.com/id32.html
Drive Shaft info:
http://chris66dad.tripod.com/id34.html
The 83 and 84 models were the ONLY years the Mustang T-5 was a NON-World Class transmission.
Beginning with 85 the bearings were redesigned and the World Class version appeared.
85-89 were virtually the same transmission for all of the V-8 models (265 ft/lbs.)
Beginning sometime in 1990 they went to a slightly stronger gear set rated at 300 ft/lbs.
For 94 and 95 the V-8 T-5s were were the same strength as the 90-93, but the input shaft was longer which required the 94/95 type "deeper" bell housing.
The 4-cylinder version of the T-5 is weaker, requires a different pilot bearing, and has a relatively useless first gear, so stay away from those.
The 94-98 V-6 types use the 85-89 strength V-8 gears, but again, have the longer inpt shaft.
The 99-04 V-6 units use the same gears as the 90-95, but have no provision for a speedometer cable since it is all-electronic.
350 used T5
25 used bellhousing
100 flywheel
150 clutch
130 cross member
30 ARP bolts
T5 conversion info;
Drive Shaft info:
the 90-93 trans are most desirable. I have 249 tag series stating cobra spec its rated higher than a non cobra spec and just lower than a z spec. (289 Ft/lbs for non cobra spec vs 310 for cobra spec I think)
AND if I recall correct the rating is based off a 100,000 miles. So a 310 rating might handle 400 ftlbs for 50,000 miles or one hard launch with sticky tires at the strip....
The 3.73s work well and still drive able on the highway. All depends on what trans you get and what the 5th gear is. They have calculators on line that can tell you you final cruising rpms with the 5th gear you have and rear gears.
I am very happy with my 3.55 with the T5.
3.80 is also good but 1st gear is a little shorter and requires a slightly quicker shift into 2nd.
It feels like we added 50-75HP to the engine with just the new gears and Trac Lok.
Great bang for the buck
JoshyGT
09-19-2017 08:52 PM
treesloth
09-28-2015 07:03 AM
uberstang1
09-20-2015 06:42 PM
