Junkyard T5's
I'm converting my 67 from auto to 5 speed, I have everything EXCEPT the trans itself. A local yard has 3 all removed from late 80's GT's. Other than physical appearance, how can I tell which is in the best condition?
No way to really tell until you install it and drive it. Or disassemble it and check out the insides.
you can try and attach a shifter real quick and put it through the gears. It won't tell you everything, but if it doesn't shift then you know it's bad. Most junkyards will give you some kind of warranty on it though, even if it's only 90 days or something like that.
make sure you only buy a world class t5.....
Why a world class? Whats the difference? Also, what do you think would be a fair price?
World class is stronger than a normal one
a world class t-5 is the strongest off-the-shelf t-5 you can buy, which really doesn't say much about the t-5 since it's only good for like 340tq or something like that...
Originally Posted by jojobanks
(Post 7821227)
Originally Posted by 1slow67
(Post 7821243)
I thought the Cobra Z spec was the strongest?
EDIT: ok I looked it up. Here's the breakdown based on manufacturer's ratings: pre-85 (non world class): 4cyl max tq- 240 8cyl max tq- 265 85-89 (world class): max tq- 265 90-93 (world class): max tq- 300 93 (cobra spec): max tq- 310 94-95: max tq- 300 "z" spec t-5: max tq- 330 of course ratios changed up all over the place as the years went on and were different in 4cyl applications. http://www.moderndriveline.com/Techn...t5_history.htm |
Probably, seems if you really want a lot of power you need a TKO or T56(which I would love to have)
| All times are GMT -5. The time now is 10:58 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
