1966 Mustang C-4 Transimmion
Old 04-09-2012, 01:47 PM
Cospanky
Cospanky's Avatar
Default 1966 Mustang C-4 Transimmion
Hello Mustang lovers. I am having a problem with my 1966 Mustang green screw in moderator C-4 tranny, it won't go into 3rd gear. I have checked the vacuum to the moderator which was 12lbs, i have removed and checked the spool valves, I have tried starting in 1st, shifting to 2nd, then to 3rd, I have taken it up over 75 MPH and none of this works. I had all new clutches replaced and still nothing. Can anyone help me?? Thank you..
Cospanky is offline
Old 04-13-2012, 05:09 PM
ThetaTau87
ThetaTau87's Avatar
I had a C4 that was shifting odd for years until I removed the pan to fix a leak and change the filter. I discovered that the ball for the check valve was missing and not controlling the fluid flow like it should. I replaced the ball and it shifter great ever since.
ThetaTau87 is offline
Old 05-28-2012, 03:26 PM
Cospanky
Cospanky's Avatar
I have not tried that one yet but will Theta. Thanks for the info.
Cospanky is offline
Old 05-28-2012, 03:31 PM
Cospanky
Cospanky's Avatar
Default Transmission problems 2nd to 3rd
Hello Mustang Fans.
I am having a problem with my 1966 Mustang C-4 transmission it won't go into 3rd gear. I have checked the vacuum to the moderator which was 12lbs, I have removed and checked the spool valves, I have tried starting in 1st, shifting to 2nd, then to 3rd, I have taken it up over 75 MPH and none of this works. I've replaced the white moderator and had all new clutches replaced and still nothing. Can anyone help me?? Thank you..
Cospanky is offline
Old 05-29-2012, 03:14 PM
jlg2002
jlg2002's Avatar
Have you checked that your intermediate servo is working?
jlg2002 is offline
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
01-06-2016 07:03 PM
chain
08-17-2015 08:52 AM
daytooday
08-11-2015 09:22 AM
Quick Reply: 1966 Mustang C-4 Transimmion
