MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   Classic Mustangs (Tech) (https://mustangforums.com/forum/classic-mustangs-tech-16/)
-   -   QTR. Windows, what's missing (https://mustangforums.com/forum/classic-mustangs-tech/669974-qtr-windows-whats-missing.html)
dmaclaren Apr 17, 2012 09:29 AM
So, both of my 1/4 windows on the 69 fastback rattle at the pin/cup.
I don't have a pic but the window, at the top, has a cup that the pin, from the upper bracket, sits into. The windows cup is larger than the pin and it rattles against the side.
So, was there a washer of some sort in there? I can't find it on line if there was. Should I just find one in a hardware store or pit in RTV sealant?
rtintwo Apr 18, 2012 07:22 AM
Its been awhile sence i messed with my quarter windows and im at work so i cant go look right now. However im pretty sure there is supposed to be a plastic bushing in there. I will take a look when i get home this afternoon if somebody else hasnt answered your question.
dmaclaren Apr 18, 2012 01:55 PM
Anyone?
BuckeyeDemon Apr 18, 2012 08:34 PM
i'm looking at a diagram and it indicates a small spacer (you're calling it a washer) of some sort that goes in that hole (with the rod going through it).
BuckeyeDemon Apr 18, 2012 08:43 PM
looks like nylon. sorry i don't have the energy to remove it tonight.
http://i258.photobucket.com/albums/h...s/IMG_2752.jpg
dmaclaren Apr 19, 2012 06:50 AM
Maybe it's a trip to Lowes to look at their washer odd drawer section. I get that it needs to be able to move (in/out) when closed for alignment issues.
I would thing 3 - 4 small washers should work.
I was also thinking putting in a bit of RTV sealant which would do the same and stay hidden without slowly riding up out of that cup.
BuckeyeDemon Apr 19, 2012 04:52 PM
your response confuses me. are you talking about stacking the washers and dropping them in the hole on the top side of the frame?
dmaclaren Apr 20, 2012 10:03 AM
If I can't find the right piece, which no luck to date, I will put the washers on the pin piece and reinstall the window. I found a couple diff sizes of the vacu-tite vacuum caps that may work if I get the right size.
http://images.oreillyauto.com/parts/.../47396-003.jpg
dmaclaren Apr 20, 2012 01:02 PM
I found the perfect size and fit. I cut a little to make it shorter but it was like these rubber vacuum caps were made for this part.
1/4" was the exact fir and they work awesome.
I will pst a pic in a few of the package, I got them at Pep Boys.
2+2GT Apr 20, 2012 05:14 PM
Not as solid or durable as a nylon bushing, but it should last for years.
© 2026 MH Sub I, LLC dba Internet Brands
