Loose Steering Wheel
It's the original one - base standard black. Liek I said before, when I replaced the turn signal switch about a year ago the wheel was tight. It's become loose since then. I'm wondering now, since it's starting to look like the shaft has moved towards the driver (is longer) if the worm gear might be worn.
As seen below at the bottom of the splines is a ridge, when you install the wheel and put it over the splines and tighten the nut it pushes the wheel down and bottoms it out on this ridge (no not the spring, the ridge on the shaft itself). Sometimes when you install the wheel it isn't all the way down and sometimes it can never go all the way down. Other times it gets installed and slowly works down further.
Did some more research and it looks like the parts you spoke of only apply to the tilt steering wheel, which I don't have. Still researching. Appreciate the reply. Did those photos come from Average Joe restoration or some other site, because I can't find a spring that is listed for a 1968.
The spring and centering bushing are standard for ALL steering column setups. If you don't have them your column wobbles and has side to side movement. You can see the spring in the photo of the 65 I linked in. The bushing is underneath the spring. The spring presses against the wheel and hold the bushing tight down in the column so the housing is always centered on the shaft.
It just dawned on me that I apparently have been using the wrong name for parts. The steering wheel sits on the SHAFT and the nut will not tighten down the steering wheel on the shaft. If I adjust the COLUMN (which I now understand is what the SHAFT sits inside of) that won't solve the problem. Am I still missing something? I apologize for my error in naming the parts involved.
09-08-2015 11:50 AM
