Intake and exhaust on 1968 289 2bbl
I have a 289 2bbl automatic on my 1968 coupe. I have a stock 4 bbl intake with a Carter 625 cfm in the garage that I would like to put on it. When I started talking about dual exhausts, my friend asked if I was changing the cam. I said "no" and his reply was "If you're not changing the cam, the single exhaust (2") will handle it, especially if you put a Series 50 Flow Master muffler on".... is he just pulling my chain, or is he legit?
Originally Posted by x757builder
(Post 8035268)
It has widely been accepted, the first mods most enthusiasts will add is a 4 barrel, dual plane intake and dual exhausts. These are the initial "given" mods. Where the "rub" occurs, is in the size of the carb. I think you'd do better with a 600 or slightly less, if buying for the first time. However, since you have that 625 setting around, then clean it up, check the float levels, give it a shot. Dial it in using a vac gauge. Experiment with advancing your initial timing a couple of degrees. ....and for God's sake, keep a log of your settings and adjustments! Your engine will benefit from what you have in mind. The choice in "muffs", is just that, a choice in the sound and Db level you're comfortable with. A great place to check them out is a car show or cruise night. Hope this helps! |
Does size matter
I agree with the previous reply posted and I too believe that the 650 CFM is a bit big based on my 351CI .030 over edelbrock 4bbl and aluminum intake, but use the carb calculator at the WWW provided below:
http://www.gtsparkplugs.com/CarbCFMCalc.html :icon_smash: |
