Oil Drip Issue - breather - pvc
Old 09-24-2012, 04:10 PM
wgc68nyc
wgc68nyc's Avatar
Default Oil Drip Issue - breather - pvc
So I run a PVC valve on the passenger side valve cover and then my oil cap is a breather on the driver side. I think some oil splash is coming up into the cap and then dripping out through the holes on the bottom and cookin on my exhaust manifold so I was thinking of replacing it with this and running a tube away from the manifold.
http://www.cjponyparts.com/scott-dra...5-1973/p/OC26/
1) Do I need a breather cap since I have a PVC valve?
2) If I run the tube away and down will it cease to work as a decent breather
wgc68nyc is offline
Old 09-25-2012, 11:24 AM
1971mach1
1971mach1's Avatar
That cap won't work with origional style valve covers. You need a screw in type breather. Use a filtered breather or hook that tube where it is supposed to be, on the air filter housing.
The purpose of a breather is that it lets fresh air into the crankcase after the PCV sucks out the bad air and gasses. If your breather is clogged, pressure builds up in the crankcase, the PCV can't suck the bad gasses out and oil is spewed out of the breather.
1971mach1 is offline
Old 09-25-2012, 12:19 PM
wgc68nyc
wgc68nyc's Avatar
I have aftermarket covers but it sounds like I should clear the filter on my exisiting breather or get the one I listed so when it does build up it drips somewhere convenient.
wgc68nyc is offline
Old 09-25-2012, 12:24 PM
1971mach1
1971mach1's Avatar
Check your PCV valve too, it also should be getting vacuum from the base of the carb.
But more likely the breather is clogged with oil and gunk.
Old 09-25-2012, 12:38 PM
wgc68nyc
wgc68nyc's Avatar
Any advice on to what to clean it out with as some residue will end up back in the engine?
wgc68nyc is offline
Old 09-25-2012, 04:00 PM
1971mach1
1971mach1's Avatar
Unless you need the origional, just buy a new one, they're around $10 or so.
I guess you could soak it in carb cleaner and let it dry out.
If it's a filtered cap (no hose), just buy a new one.
10-26-2015 05:01 PM
LivingInThePast
09-16-2015 12:20 PM
MusicCity615
09-12-2015 07:05 AM
Pyrate Dave
09-10-2015 07:30 PM
kevsgt
09-09-2015 06:20 AM
Quick Reply: Oil Drip Issue - breather - pvc
