Whats wrong with this picture?
I have three inches radiator to pump pully. My Efan is 3-3/8" so it wont fit.
Looking at the water pump, should I have a short snout? Is the pully setup I have correct, minus the missing PS and AC?
Thanks guys!! I need to get a fan on here somehow fast and cheap. Im ok with running mech fan too. Please help!
Hi again,
So, I see you're running a stroker. So do I. Mine's a 334 (.040 over). I run a 17" Flexlite blade and a radiator shroud. This combination has served me well over the years. Also, a coolant recovery system. It insures maximum coolant levels throughout the system. Check with NPD for the fan extension.
Good Luck
Good Luck
Hi again,
Good Luck
Good Luck
Wondering it I should try this http://www.ebay.com/itm/16-Fan-2-Row...-/150873441046
What radiator is in it currently? I have a tight fight with my thicker than stock Fluidyne radiator. I'm running a Derale rigid fan from Summit and the composite shroud. I think the fan is 17 inch. It works well.
Matt's 95 Stang
10-05-2015 07:16 AM
